Need guidance in selecting a Lowboy
Hey guys,
I really like the looks of the cabinet used for the 76, 85/86, and 95/96 chassis's, and would like to obtain one.
Can anyone advise about the chassis's -7, 8, & 9 tube-  AFA ease or difficulty of restoring electronically, obtaining specific parts, and if any are either particularly superior or inferior AFA performance?
Any advice appreciated!
Need guidance in selecting a Lowboy - by fifties - 02-16-2018, 04:15 PM
There are currently 10761 online users. [Complete List]
» 3 Member(s) | 10758 Guest(s)
