Westinghouse WR10A
All, OK started on this..
[Image: https://farm5.staticflickr.com/4700/2543...efce_b.jpg]
[Image: https://farm5.staticflickr.com/4628/3959...639f_b.jpg]
Question How do you remove the Tuning Capacitor?
Looks like you have to take off the dial.. But have no clue how to do that..
Skip..
Westinghouse WR10A - by vecher - 02-17-2018, 12:36 AM
RE: Westinghouse WR10A - by Phlogiston - 02-17-2018, 12:00 PM
RE: Westinghouse WR10A - by vecher - 02-17-2018, 11:16 PM
RE: Westinghouse WR10A - by vecher - 02-27-2018, 08:26 PM
RE: Westinghouse WR10A - by Radioroslyn - 02-27-2018, 09:58 PM
RE: Westinghouse WR10A - by vecher - 02-28-2018, 02:26 AM
RE: Westinghouse WR10A - by David - 02-28-2018, 09:18 AM
RE: Westinghouse WR10A - by Eliot Ness - 02-28-2018, 09:36 AM
RE: Westinghouse WR10A - by EdHolland - 02-28-2018, 05:42 PM
RE: Westinghouse WR10A - by vecher - 03-31-2018, 12:03 AM
RE: Westinghouse WR10A - by Arran - 03-31-2018, 12:30 AM
RE: Westinghouse WR10A - by vecher - 04-01-2018, 12:21 AM
RE: Westinghouse WR10A - by Phlogiston - 04-01-2018, 10:51 AM
RE: Westinghouse WR10A - by vecher - 04-11-2018, 11:02 PM
RE: Westinghouse WR10A - by rfeenstra - 04-11-2018, 11:54 PM
RE: Westinghouse WR10A - by Eliot Ness - 04-12-2018, 05:38 AM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 06:55 PM
RE: Westinghouse WR10A - by Radioroslyn - 04-14-2018, 08:22 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 10:45 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 11:23 PM
RE: Westinghouse WR10A - by vecher - 04-16-2018, 12:38 AM
There are currently 5950 online users. [Complete List]
» 1 Member(s) | 5949 Guest(s)
