Emerson 267
Yet the Radioattic pic is the correct radio.
I did get the number from the chassis as all the decals are gone.
I printed out the CM267 schematic and it looks more correct than what I had. Will have to investigate.
Thanks guys
Emerson 267 - by TimC - 05-04-2010, 06:12 PM
Re: Emerson 267 - by denver - 05-04-2010, 08:26 PM
Re: Emerson 267 - by TimC - 05-04-2010, 09:01 PM
Re: Emerson 267 - by denver - 05-04-2010, 09:02 PM
Re: Emerson 267 - by exray - 05-04-2010, 09:18 PM
Re: Emerson 267 - by denver - 05-04-2010, 09:51 PM
Re: Emerson 267 - by denver - 05-04-2010, 09:53 PM
Re: Emerson 267 - by TimC - 05-05-2010, 07:50 AM
Re: Emerson 267 - by denver - 05-05-2010, 10:03 PM
Philco 91 Tuning Condenser
There are currently 10162 online users. [Complete List]
» 2 Member(s) | 10160 Guest(s)
