MODEL111&111A
I was looking for schematics for other people . And was at radio museum just happend on a discussion about the philco 111& 111a what the difference was .
They had no ideal does any one know ? They had a set of legs made into a bench that came from plant#25 . Does any one know the difference .
Thanks Kent.
MODEL111&111A - by denver - 05-05-2010, 09:55 PM
Re: MODEL111&111A - by Chuck Schwark - 05-05-2010, 10:04 PM
Re: MODEL111&111A - by denver - 05-06-2010, 04:58 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
