Philco 40-201
I am working on a Philco model 40-201 (should be electrically identical to a 40-195).  I have found an extra part (resistor) in the unit, it appears to be factory installed. There is a 4700 ohm resistor in parallel with the secondary of the short wave oscillator coil, see attached illustration. I am not smart enough to know what this does.  Comments from the experts will be appreciated.
Philco 40-201 - by TFB - 02-18-2018, 11:53 PM
RE: Philco 40-201 - by Radioroslyn - 02-19-2018, 01:17 AM
RE: Philco 40-201 - by TFB - 02-19-2018, 08:25 PM
The speaker table error?
Philco 70 antenna lead
