Philco 40-201
Well I'm not sure exactly why it's there but it lowers the Q of the osc secondary. I would leave it in the circuit as it was probably added to correct a problem from a earlier run that isn't documented.
Philco 40-201 - by TFB - 02-18-2018, 11:53 PM
RE: Philco 40-201 - by Radioroslyn - 02-19-2018, 01:17 AM
RE: Philco 40-201 - by TFB - 02-19-2018, 08:25 PM
The speaker table error?
Philco 70 antenna lead
