Grill Cloth Philco 70 Source
Good morning Wilbur,
Sadly, there are really only two sources for grille cloth nowadays, and patterns are limited.
RadioDaze and Richmond Design.
http://www.richmonddesignsinc.com
http://www.radiodaze.com
I've purchased from both, and had good luck.
Grill Cloth Philco 70 Source - by Radiowilbur - 02-19-2018, 11:43 AM
RE: Grill Cloth Philco 70 Source - by Brad Winder - 02-19-2018, 12:16 PM
There are currently 10218 online users. [Complete List]
» 2 Member(s) | 10216 Guest(s)
