Philco Model 76 Chassis Restoration ?
Thank you comrade!
I will replace my .25 with a .05 at the No: 13 position and see if this solves my problem.
Testing tubes is a bit harder for me but I will get them done.
Rich
RE: Philco Model 76 Chassis Restoration ? - by rmarc7828 - 02-19-2018, 02:55 PM
The speaker table error?
Philco 70 antenna lead
