Can anyone help with instructions? (Pink)Model #F-758-124
Ive recently purchased a Pink Alarm Clock Radio - Model #F-758-124 for resale.
I have a potential customer that would like to know how to set the alarm clock and if it does work.
I can set the clock with the small knob in the back, and I can also move the "red" hand with that knob as well.
Can anyone help me with this?
Thank you!
Philco 91 Tuning Condenser
