Worn phono/radio button
I'd try cleaning the switch w/some contact cleaner.
Worn phono/radio button - by philco4me - 02-22-2018, 02:28 PM
RE: Worn phono/radio button - by Radioroslyn - 02-22-2018, 02:36 PM
RE: Worn phono/radio button - by philco4me - 02-22-2018, 02:42 PM
RE: Worn phono/radio button - by Kestas - 02-22-2018, 04:04 PM
RE: Worn phono/radio button - by Radioroslyn - 02-22-2018, 04:23 PM
RE: Worn phono/radio button - by Ron Ramirez - 02-22-2018, 04:48 PM
The speaker table error?
Philco 70 antenna lead
