Worn phono/radio button
Ok Plan B
Inspect the switch for damage, broken contacts, broken wafer, ect. And go from there.
Plan C
There is a small possibility that the switch isn't the problem but is cause something else to
act up. To troubleshoot this a signal tracer is your best friend.
OBTW you might want to update your profile, as of a couple of yrs ago your city and
state were added as a must.
Worn phono/radio button - by philco4me - 02-22-2018, 02:28 PM
RE: Worn phono/radio button - by Radioroslyn - 02-22-2018, 02:36 PM
RE: Worn phono/radio button - by philco4me - 02-22-2018, 02:42 PM
RE: Worn phono/radio button - by Kestas - 02-22-2018, 04:04 PM
RE: Worn phono/radio button - by Radioroslyn - 02-22-2018, 04:23 PM
RE: Worn phono/radio button - by Ron Ramirez - 02-22-2018, 04:48 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6848 online users. [Complete List]
» 2 Member(s) | 6846 Guest(s)
