Philco 70 and similar ground leakage
First off, I would try the water pipe anyway - it is there, and it is easy. If it is connected with the water supply, grounding can be very good.
There is no problem making and using a separate RF ground such as a ground rod, as long as it is not used as part of the electrical supply safety ground.
Philco 70 and similar ground leakage - by ntsc525 - 10-22-2017, 01:38 PM
RE: Philco 70 and similar ground leakage - by EdHolland - 02-25-2018, 12:01 PM
The speaker table error?
Philco 70 antenna lead
