Zenith 10s464 question's
I did look into cleaning the pot, but this one does not an access hole for cleaning.
Probably could remove it and take it apart, but I am hoping that I won't have to take it out again.
Do generally clean the tube pins when I test the tubes.
Possibly a dirty socket?
murf
Zenith 10s464 question's - by murf - 02-24-2018, 07:13 PM
RE: Zenith 19s464 question's - by Eliot Ness - 02-25-2018, 09:53 AM
RE: Zenith 10s464 question's - by murf - 02-25-2018, 01:12 PM
RE: Zenith 10s464 question's - by tbone - 02-26-2018, 07:23 PM
RE: Zenith 10s464 question's - by murf - 02-26-2018, 08:00 PM
RE: Zenith 10s464 question's - by tbone - 02-26-2018, 08:05 PM
New member
Philco 630csx power cord
New member
There are currently 3998 online users. [Complete List]
» 3 Member(s) | 3995 Guest(s)
