Connecting Test Equipment to AA5 radio
With the isolation transformer you can connect the - lead right to the chaiss. Without the use of an isolation transformer you can measure the voltage from earth ground to chaiss ground. If you get 120vac flip the ac plug around and you should measure a small amount of ac, the difference from neutral to earth ground. Just make sure you don't have 120v from the chaiss to ground and you will be fine.
Connecting Test Equipment to AA5 radio - by Guest - 05-07-2010, 12:50 PM
Re: Connecting Test Equipment to AA5 radio - by 7estatdef - 05-07-2010, 06:14 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
