Chassis Difference?
Hi,
I have a 40-195, and my 39-40 chassis is now up for auction on Ebay until late Monday night. I was able to put the 39-40 in the 40-195's cabinet when its chassis was on the bench, but the pushbuttons needed to be a different length. The 40-195 has 3 bands, the 39-40 just two (no police band). I believe the speaker is the same for either set...
Chassis Difference? - by n9vu - 01-28-2006, 02:26 PM
[No subject] - by Chuck Schwark - 01-28-2006, 03:10 PM
[No subject] - by n9vu - 01-28-2006, 04:37 PM
[No subject] - by Ron Ramirez - 01-28-2006, 06:16 PM
[No subject] - by Guest - 01-28-2006, 07:21 PM
[No subject] - by n9vu - 01-28-2006, 08:07 PM
There are currently 9803 online users. [Complete List]
» 1 Member(s) | 9802 Guest(s)
