Evapo-Rust Gel
Excellent news! I'm a big fan of Evaporust. It may take a while but does not harm other materials like Naval Jelly can.
I have used T-9 on several projects with very good results. It's basically wax dissolved in a solvent and does a good job keeping the metal protected.
Evapo-Rust Gel - by Nathan Slingerland - 02-18-2018, 02:45 PM
RE: Evapo-Rust Gel - by klondike98 - 02-18-2018, 09:16 PM
RE: Evapo-Rust Gel - by Tubesforme - 02-26-2018, 08:19 PM
RE: Evapo-Rust Gel - by Bob Andersen - 02-26-2018, 11:21 PM
The speaker table error?
Philco 70 antenna lead
