Westinghouse WR10A
Careful use of a pair of small strap wrenches (example below just for reference):
https://www.amazon.com/Craftsman-Piece-R...Src=detail
After you try a better penetrating oil.  Similar to what Dave mentioned is a 50/50 mix of ATF and acetone:
http://www.rx8club.com/attachments/serie...le0001.pdf
If you decide to buy a local product rather than mixing your own the above test shows that Liquid Wrench works almost as well as Kroil but costs a lot less.
Westinghouse WR10A - by vecher - 02-17-2018, 12:36 AM
RE: Westinghouse WR10A - by Phlogiston - 02-17-2018, 12:00 PM
RE: Westinghouse WR10A - by vecher - 02-17-2018, 11:16 PM
RE: Westinghouse WR10A - by vecher - 02-27-2018, 08:26 PM
RE: Westinghouse WR10A - by Radioroslyn - 02-27-2018, 09:58 PM
RE: Westinghouse WR10A - by vecher - 02-28-2018, 02:26 AM
RE: Westinghouse WR10A - by David - 02-28-2018, 09:18 AM
RE: Westinghouse WR10A - by Eliot Ness - 02-28-2018, 09:36 AM
RE: Westinghouse WR10A - by EdHolland - 02-28-2018, 05:42 PM
RE: Westinghouse WR10A - by vecher - 03-31-2018, 12:03 AM
RE: Westinghouse WR10A - by Arran - 03-31-2018, 12:30 AM
RE: Westinghouse WR10A - by vecher - 04-01-2018, 12:21 AM
RE: Westinghouse WR10A - by Phlogiston - 04-01-2018, 10:51 AM
RE: Westinghouse WR10A - by vecher - 04-11-2018, 11:02 PM
RE: Westinghouse WR10A - by rfeenstra - 04-11-2018, 11:54 PM
RE: Westinghouse WR10A - by Eliot Ness - 04-12-2018, 05:38 AM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 06:55 PM
RE: Westinghouse WR10A - by Radioroslyn - 04-14-2018, 08:22 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 10:45 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 11:23 PM
RE: Westinghouse WR10A - by vecher - 04-16-2018, 12:38 AM
There are currently 4496 online users. [Complete List]
» 2 Member(s) | 4494 Guest(s)
