Philco 90 Cathedral
Medium Walnut.
If you're careful, you might add some Medium Dark Walnut in the grooves of the pillars on the left and right sides of the front panel.
Philco 90 Cathedral - by frankpe - 05-10-2010, 06:20 PM
Re: Philco 90 Cathedral - by Ron Ramirez - 05-10-2010, 06:39 PM
Re: Philco 90 Cathedral - by frankpe - 05-10-2010, 08:43 PM
Re: Philco 90 Cathedral - by Ron Ramirez - 05-10-2010, 09:37 PM
