  • 3 Vote(s) - 2.33 Average
AM transmitter build - by Tim
The reason I add preamp & gain control is for line level signal, input transformer is for direct coupling from a amp output... I orignally built my 6888 without the preamp, next day I was adding it...
The low impedance of std output xfomer will likely load a line signal till it'll be unusable...
AM transmitter build - by Tim - by TV MAN - 03-01-2018, 02:48 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-01-2018, 02:58 PM
RE: AM transmitter build - by Tim - by sam - 03-01-2018, 03:51 PM
RE: AM transmitter build - by Tim - by fenbach - 03-01-2018, 09:08 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-01-2018, 11:35 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 12:00 AM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 12:32 AM
RE: AM transmitter build - by Tim - by 35Z5 - 03-02-2018, 12:29 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-02-2018, 01:29 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-02-2018, 03:48 PM
RE: AM transmitter build - by Tim - by sam - 03-05-2018, 02:14 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-09-2018, 12:37 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-10-2018, 11:33 AM
RE: AM transmitter build - by Tim - by TV MAN - 03-10-2018, 01:13 PM
RE: AM transmitter build - by Tim - by Phlogiston - 03-10-2018, 01:22 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-10-2018, 03:20 PM
RE: AM transmitter build - by Tim - by sam - 03-11-2018, 06:30 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-21-2018, 10:56 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-23-2018, 12:11 AM
RE: AM transmitter build - by Tim - by 35Z5 - 03-23-2018, 09:37 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-24-2018, 08:36 PM
RE: AM transmitter build - by Tim - by TV MAN - 03-26-2018, 11:30 PM
RE: AM transmitter build - by Tim - by 35Z5 - 03-28-2018, 07:52 AM
RE: AM transmitter build - by Tim - by TV MAN - 04-08-2018, 03:54 PM
RE: AM transmitter build - by Tim - by TV MAN - 10-29-2018, 10:01 AM
RE: AM transmitter build - by Tim - by EdHolland - 11-02-2018, 12:08 AM
RE: AM transmitter build - by Tim - by morzh - 11-02-2018, 11:18 AM
RE: AM transmitter build - by Tim - by EdHolland - 11-02-2018, 04:50 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-05-2018, 02:40 PM
RE: AM transmitter build - by Tim - by jcassity - 11-07-2018, 04:34 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-12-2018, 01:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-20-2018, 06:47 PM
RE: AM transmitter build - by Tim - by Eliot Ness - 11-20-2018, 09:13 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-25-2018, 06:30 PM
RE: AM transmitter build - by Tim - by KCMike - 11-25-2018, 06:56 PM
RE: AM transmitter build - by Tim - by Phlogiston - 11-25-2018, 07:17 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-26-2018, 12:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-26-2018, 05:07 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-30-2018, 09:19 PM
RE: AM transmitter build - by Tim - by TV MAN - 11-30-2018, 09:30 PM
RE: AM transmitter build - by Tim - by 35Z5 - 11-30-2018, 10:44 PM
RE: AM transmitter build - by Tim - by TV MAN - 12-14-2018, 06:38 PM
RE: AM transmitter build - by Tim - by EdHolland - 12-14-2018, 08:24 PM
RE: AM transmitter build - by Tim - by TV MAN - 12-15-2018, 11:02 AM
RE: AM transmitter build - by Tim - by Phlogiston - 12-23-2018, 12:27 PM
RE: AM transmitter build - by Tim - by TV MAN - 01-29-2019, 02:00 PM
RE: AM transmitter build - by Tim - by TV MAN - 01-29-2019, 02:28 PM
RE: AM transmitter build - by Tim - by sam - 01-29-2019, 02:38 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 2129 online users. [Complete List]
» 4 Member(s) | 2125 Guest(s)
AvatarAvatarAvatarAvatar
