38-1 grille cloth
Thank you Ron! I think I got the pattern as close and evenly spaced on the board as I could, especially the section of pattern in the middle- even now, I can tweak it close to perfection in the center rungs, but the outer edges need to be dropped just a smidgen. I said I pulled the fabric up completely twice, with hundreds of mini adjustments which consisted of pulling the cloth up and out in spots. The Chevron pattern was giving a strange effect on my eyes after awhile, kind of like those "magic eye" posters. After several days of fooling with it, I got quite ill and needed a whole day to recuperate from the exhausting experience... Icon_sick I'll not be doing another one of those for a long while...
38-1 grille cloth - by Electrothaumaturgist - 01-26-2018, 10:38 PM
RE: 38-1 grille cloth - by Ron Ramirez - 01-26-2018, 11:35 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 01-27-2018, 12:14 AM
RE: 38-1 grille cloth - by Electrothaumaturgist - 02-02-2018, 09:27 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 03-01-2018, 05:27 PM
RE: 38-1 grille cloth - by Ron Ramirez - 03-01-2018, 07:11 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 03-01-2018, 07:56 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 03-02-2018, 06:45 PM
RE: 38-1 grille cloth - by Ron Ramirez - 03-02-2018, 07:12 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 03-02-2018, 07:53 PM
RE: 38-1 grille cloth - by Brad Winder - 03-04-2018, 01:46 PM
RE: 38-1 grille cloth - by Kenneth F. Besso Jr. - 03-04-2018, 02:35 PM
RE: 38-1 grille cloth - by Electrothaumaturgist - 03-04-2018, 03:51 PM
Eico 232 VTVM Schematic
There are currently 9058 online users. [Complete List]
» 1 Member(s) | 9057 Guest(s)
