Philco 77 Dial String Problem
Just finished a Philco Model 77 and it is playing great, but......
I noticed that the dial string was a bit loose, so decided to replace it. I have used regular dial string as well as copper braid, but both slip on the drive pulley attached to the tuning knob. The original string was thicker and a bit softer than usual. I think I need a large diameter string. Any tips on how to solve this or where I can find the correct dial string?  Anyone have the dial stringing diagram handy?
Joe
Philco 77 Dial String Problem - by jamr005 - 03-03-2018, 08:20 PM
RE: Philco 77 Dial String Problem - by rfeenstra - 03-03-2018, 09:05 PM
RE: Philco 77 Dial String Problem - by rfeenstra - 03-03-2018, 09:07 PM
RE: Philco 77 Dial String Problem - by jamr005 - 03-04-2018, 07:47 PM
The speaker table error?
Philco 70 antenna lead
