Scott 16A
A lot of 6200 mmf caps in the FM IF section.  these are very likely not mica's?  I could find one of the listed replacement cap brand's part number and it does show up as mica for that brand.  I could not cross the other brands listed to verify.  To replace them with mica's is very expensive from mouser.
Scott 16A - by rfeenstra - 01-28-2018, 03:03 PM
RE: Scott 16A - by Brad Winder - 01-29-2018, 10:46 PM
RE: Scott 16A - by morzh - 01-30-2018, 10:20 AM
RE: Scott 16A - by rfeenstra - 01-30-2018, 06:39 PM
RE: Scott 16A - by Electrothaumaturgist - 01-30-2018, 07:37 PM
RE: Scott 16A - by rfeenstra - 01-30-2018, 08:31 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 03:43 PM
RE: Scott 16A - by Phlogiston - 03-03-2018, 05:16 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 08:51 PM
RE: Scott 16A - by Phlogiston - 03-03-2018, 09:02 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 09:21 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 11:52 PM
RE: Scott 16A - by Phlogiston - 03-04-2018, 10:41 AM
RE: Scott 16A - by rfeenstra - 05-08-2018, 12:21 AM
RE: Scott 16A - by morzh - 05-08-2018, 08:58 AM
RE: Scott 16A - by Arran - 05-09-2018, 05:05 AM
RE: Scott 16A - by rfeenstra - 05-09-2018, 08:48 AM
RE: Scott 16A - by morzh - 05-09-2018, 09:49 AM
RE: Scott 16A - by Phlogiston - 05-09-2018, 10:02 AM
There are currently 9265 online users. [Complete List]
» 2 Member(s) | 9263 Guest(s)
