New member with a Philco 41-608
Any tips or info on BOL lamp, Photovoltaic cell replacement, or indicators bulbs for the HR-1 record cutter option would be much appreciated.  Or just direct me to old string of relevant posts.
Rick
New member with a Philco 41-608 - by Ricky L. Adkins - 03-04-2018, 06:00 PM
RE: New member with a Philco 41-608 - by sam - 03-05-2018, 01:21 PM
RE: New member with a Philco 41-608 - by sam - 03-06-2018, 12:22 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7109 online users. [Complete List]
» 2 Member(s) | 7107 Guest(s)
