Philco 77 Dial String Problem
I fixed the problem.  Used regular dial string (the thinner stuff).  I made a full revolution around the pulley attached to the tuning knob and voila it works just fine.  I didn't need to go with a larger diameter cord.
Now I have one last problem to resolve with my antenna and ground posts.  They are clearly spring-loaded but they won't push down to accept a wire.  I have WD-40 ed them and also used turbine oil, but still can't get them to push down.  Anyone else have this problem?  Am I doing something wrong?
Thanks everyone,
Joe Miller
Philco 77 Dial String Problem - by jamr005 - 03-03-2018, 08:20 PM
RE: Philco 77 Dial String Problem - by rfeenstra - 03-03-2018, 09:05 PM
RE: Philco 77 Dial String Problem - by rfeenstra - 03-03-2018, 09:07 PM
RE: Philco 77 Dial String Problem - by jamr005 - 03-04-2018, 07:47 PM
The speaker table error?
Philco 70 antenna lead
