BOL Question
Yes, thanks for the info. I have looked at the schematic and I believe I now know how to connect all of the wires...they were disconnected when I got the 41-608. I have done some preliminary testing, and the detector appears to be putting out a fairly good mV signal when I shine a light on it...but I will know more once I get the system to the point where I can apply power to the set. I still have to do a recap on the unit, and rewire the power cord.
Rick
BOL Question - by marv - 06-09-2014, 01:58 PM
RE: BOL Question - by morzh - 06-09-2014, 02:08 PM
RE: BOL Question - by Sean - 06-09-2014, 04:18 PM
RE: BOL Question - by marv - 06-09-2014, 05:07 PM
RE: BOL Question - by Ricky L. Adkins - 03-06-2018, 10:11 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5972 online users. [Complete List]
» 1 Member(s) | 5971 Guest(s)
