A little help Please
> After a few wiring changes, I have between the positive side #26 and plate of 7A8 29.2 ohms. And from positive side of #26 to plate of 7B7 20.3 ohms.
Ok so that's good.
>Watching B+ on power up and looking for around 95V, shut down when voltage climbed above 105V.
105v is not much of a big deal, filter caps are rated @ 150 or 160v. Typically the dc output voltage isn't
going to rise above the ac input to the rectifier if there is some load on the p/s.
>May have done some damage as on 2nd attempt B+ only climbed to around 30V.
Seems like you have short somewhere on the hv rail or a weak 35Z3.
A little help Please - by elfiself - 02-27-2018, 09:41 AM
RE: A little help Please - by Radioroslyn - 02-27-2018, 10:57 AM
RE: A little help Please - by elfiself - 02-27-2018, 02:24 PM
RE: A little help Please - by Radioroslyn - 02-27-2018, 02:58 PM
RE: A little help Please - by elfiself - 02-28-2018, 02:56 PM
RE: A little help Please - by Radioroslyn - 02-28-2018, 05:32 PM
RE: A little help Please - by elfiself - 02-28-2018, 06:01 PM
RE: A little help Please - by elfiself - 02-28-2018, 07:18 PM
RE: A little help Please - by elfiself - 03-07-2018, 11:11 AM
RE: A little help Please - by Radioroslyn - 03-07-2018, 12:15 PM
RE: A little help Please - by elfiself - 03-07-2018, 02:21 PM
RE: A little help Please - by Radioroslyn - 03-07-2018, 03:18 PM
RE: A little help Please - by elfiself - 03-07-2018, 04:19 PM
RE: A little help Please - by Radioroslyn - 03-07-2018, 05:19 PM
RE: A little help Please - by elfiself - 03-07-2018, 08:25 PM
RE: A little help Please - by Radioroslyn - 03-07-2018, 09:09 PM
RE: A little help Please - by elfiself - 03-09-2018, 03:39 PM
RE: A little help Please - by morzh - 03-09-2018, 04:39 PM
RE: A little help Please - by elfiself - 03-09-2018, 05:13 PM
RE: A little help Please - by Radioroslyn - 03-09-2018, 05:34 PM
RE: A little help Please - by elfiself - 03-09-2018, 05:51 PM
RE: A little help Please - by elfiself - 03-10-2018, 01:04 AM
RE: A little help Please - by morzh - 03-10-2018, 10:48 AM
RE: A little help Please - by elfiself - 03-10-2018, 11:41 AM
RE: A little help Please - by morzh - 03-10-2018, 11:46 AM
RE: A little help Please - by elfiself - 03-10-2018, 11:48 AM
Users browsing this thread: 14 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4837 online users. [Complete List]
» 1 Member(s) | 4836 Guest(s)
