Westinghouse N 202 ?
Is this an American made radio? Reason for asking is that sometimes Canadian made radios have their own numbering system. 'N' is an unusual prefix for a Westinghouse. Is there anything about it that may indicate an export version?
Westinghouse N 202 ? - by mickey1 - 05-12-2010, 09:10 AM
Re: Westinghouse N 202 ? - by denver - 05-12-2010, 10:35 AM
Re: Westinghouse N 202 ? - by mickey1 - 05-13-2010, 02:38 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 04:07 PM
Re: Westinghouse N 202 ? - by exray - 05-13-2010, 05:34 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 06:22 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 09:41 PM
Re: Westinghouse N 202 ? - by mickey1 - 05-14-2010, 08:44 AM
Re: Westinghouse N 202 ? - by mickey1 - 05-15-2010, 12:50 PM
Re: Westinghouse N 202 ? - by denver - 05-15-2010, 01:54 PM
Philco 91 Tuning Condenser
There are currently 6981 online users. [Complete List]
» 2 Member(s) | 6979 Guest(s)
