1936 Philco model 84 cathedral
All the caps in the bakelite blocks should be replaced and all resistor values checked and if off value changed ground on 77 tube checked.
vinzer
1936 Philco model 84 cathedral - by Guest - 05-13-2010, 04:35 PM
Re: 1936 Philco model 84 cathedral - by vinzer - 05-13-2010, 08:11 PM
Re: 1936 Philco model 84 cathedral - by hotrod - 05-13-2010, 10:17 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-13-2010, 11:53 PM
Re: 1936 Philco model 84 cathedral - by Guest - 05-14-2010, 02:05 AM
Re: 1936 Philco model 84 cathedral - by denver - 05-14-2010, 02:10 PM
Re: 1936 Philco model 84 cathedral - by vinzer - 05-14-2010, 03:58 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-14-2010, 07:04 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-14-2010, 07:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
