Question regarding capacitors
I just restuffed twistlocks from my EICO amps with two 22uF 450V caps. I use EEUEB series by Panasonic exclusively. Very good cap. The EEU-EB2W220, a 22uF 450V is 560mA ripple at 120Hz. Two of them in parallel make more than sufficient input cap for my amps and in series they make an input cap for any hi end radio. I bought a bag of them on sale (was about to buy from Mouser when I saw them sold cheaply on some supply site as long as you bought 70pcs).
Question regarding capacitors - by Ron Ramirez - 03-06-2018, 10:10 PM
RE: Question regarding capacitors - by morzh - 03-06-2018, 11:08 PM
RE: Question regarding capacitors - by Arran - 03-07-2018, 12:05 AM
RE: Question regarding capacitors - by Arran - 03-07-2018, 08:26 PM
RE: Question regarding capacitors - by Phlogiston - 03-07-2018, 08:45 PM
RE: Question regarding capacitors - by EdHolland - 03-09-2018, 06:32 PM
RE: Question regarding capacitors - by Arran - 03-10-2018, 12:22 AM
RE: Question regarding capacitors - by morzh - 03-10-2018, 10:51 AM
RE: Question regarding capacitors - by Phlogiston - 03-10-2018, 11:22 AM
RE: Question regarding capacitors - by tbone - 03-10-2018, 05:32 PM
RE: Question regarding capacitors - by Phlogiston - 03-10-2018, 10:34 PM
RE: Question regarding capacitors - by morzh - 03-10-2018, 11:15 PM
RE: Question regarding capacitors - by tbone - 03-11-2018, 07:27 AM
RE: Question regarding capacitors - by morzh - 03-11-2018, 08:45 PM
RE: Question regarding capacitors - by Arran - 03-11-2018, 09:08 PM
RE: Question regarding capacitors - by etech - 04-06-2018, 12:43 PM
RE: Question regarding capacitors - by Phlogiston - 04-06-2018, 01:16 PM
RE: Question regarding capacitors - by etech - 04-06-2018, 03:22 PM
RE: Question regarding capacitors - by etech - 04-08-2018, 08:34 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6864 online users. [Complete List]
» 1 Member(s) | 6863 Guest(s)
