1936 Philco model 84 cathedral
Awsome, awsome, awsome! Thank you all very much! Very good info. I was wondering if there were something inside those bakelite blocks. I just now acquired a schematic for this puppy and it shows those paper caps, but could not see them under the chassis! 8)
I was just checking the first coil which I believe (according to the schematic) is the antenna coil. It has good continuity. Which one is the oscillator coil?
1936 Philco model 84 cathedral - by Guest - 05-13-2010, 04:35 PM
Re: 1936 Philco model 84 cathedral - by vinzer - 05-13-2010, 08:11 PM
Re: 1936 Philco model 84 cathedral - by hotrod - 05-13-2010, 10:17 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-13-2010, 11:53 PM
Re: 1936 Philco model 84 cathedral - by Guest - 05-14-2010, 02:05 AM
Re: 1936 Philco model 84 cathedral - by denver - 05-14-2010, 02:10 PM
Re: 1936 Philco model 84 cathedral - by vinzer - 05-14-2010, 03:58 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-14-2010, 07:04 PM
Re: 1936 Philco model 84 cathedral - by 7estatdef - 05-14-2010, 07:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
