Westinghouse N 202 ?
Thanks for the info Icon_biggrin beginning to think I was loosing it Icon_redface being new to rebuilding i tried all the resources i could find. will look up the M102. there are some numbers on the chasis will post later. Looks as if repairs made earlier? a lot of heat damage have not tried to power up yet recapping and resister change.
Icon_biggrin later
Westinghouse N 202 ? - by mickey1 - 05-12-2010, 09:10 AM
Re: Westinghouse N 202 ? - by denver - 05-12-2010, 10:35 AM
Re: Westinghouse N 202 ? - by mickey1 - 05-13-2010, 02:38 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 04:07 PM
Re: Westinghouse N 202 ? - by exray - 05-13-2010, 05:34 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 06:22 PM
Re: Westinghouse N 202 ? - by denver - 05-13-2010, 09:41 PM
Re: Westinghouse N 202 ? - by mickey1 - 05-14-2010, 08:44 AM
Re: Westinghouse N 202 ? - by mickey1 - 05-15-2010, 12:50 PM
Re: Westinghouse N 202 ? - by denver - 05-15-2010, 01:54 PM
Philco 91 Tuning Condenser
There are currently 6912 online users. [Complete List]
» 2 Member(s) | 6910 Guest(s)
