Three GE Transistor Radios
I might try that the next time I am in the radios to swap batteries. I noticed the earlier 'A' model doesn't tend to rattle the case like the later two with the reed speakers. One bad thing I've read about these radios is that they tend to be battery eaters. I've seen claims of only 30 hours on modern 9 volt batteries, even recapped. Guess there was a reason why GE used an expensive, chunky 9 volt in these! Oh, and one site even claimed the magnets can fall off the reed speakers, though both of mine seem good and strong. As far as batteries go, wonder how a high end lithium battery would do in these? I think I've seen 9 volt versions of those.
Three GE Transistor Radios - by Jayce - 03-12-2018, 04:46 PM
RE: Three GE Transistor Radios - by David - 03-12-2018, 07:32 PM
RE: Three GE Transistor Radios - by Jayce - 03-12-2018, 09:47 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 07:47 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 AM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 05:10 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 08:55 PM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 09:15 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 09:19 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 PM
RE: Three GE Transistor Radios - by Arran - 03-14-2018, 12:07 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 11:28 AM
RE: Three GE Transistor Radios - by Jayce - 03-14-2018, 12:12 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 05:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 05:02 PM
RE: Three GE Transistor Radios - by Jayce - 03-19-2018, 10:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 11:42 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-30-2018, 05:49 PM
RE: Three GE Transistor Radios - by Jayce - 03-30-2018, 11:51 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-31-2018, 08:39 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-02-2018, 08:03 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-05-2018, 09:48 AM
RE: Three GE Transistor Radios - by Jayce - 04-06-2018, 10:06 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-07-2018, 12:02 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-08-2018, 10:46 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-12-2018, 08:46 PM
RE: Three GE Transistor Radios - by Jayce - 04-12-2018, 10:13 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-18-2018, 11:51 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-25-2018, 06:34 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 03:40 PM
RE: Three GE Transistor Radios - by Jayce - 05-05-2018, 04:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 11:25 PM
RE: Three GE Transistor Radios - by jcassity - 05-12-2018, 08:20 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-27-2018, 06:18 PM
RE: Three GE Transistor Radios - by sam - 05-27-2018, 06:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-30-2018, 06:02 PM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 12:18 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 10:23 AM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 02:54 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 09:26 PM
RE: Three GE Transistor Radios - by 35Z5 - 06-05-2018, 04:40 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2534 online users. [Complete List]
» 2 Member(s) | 2532 Guest(s)
