Fisher Custom Electra hum issue
anything with a switching supply can cause noise.  I've "de-buzzed" a lot of LED lights and dimmers by putting a choke in the AC line. I think an LED in a piece of electronic equipment won't buzz unless the it is supplied with a switching supply or a DC to DC converter.  I had a couple of momentray buzzes every few seconds that turned out to be battery chargers for my various battery powered tools.  Very annoying.
Fisher Custom Electra hum issue - by patrician56 - 03-12-2018, 09:28 PM
RE: Fisher Custom Electra hum issue - by TV MAN - 03-13-2018, 08:52 AM
RE: Fisher Custom Electra hum issue - by rfeenstra - 03-13-2018, 09:39 AM
