Need guidance in selecting a Lowboy
He got back to me and said that he was selling 8 consoles, not one. Good luck with that. I told him my offer stands unless/until I find another.
BTW, if anyone has one of these consoles they could part with, I'd be interested, obviously.
Need guidance in selecting a Lowboy - by fifties - 02-16-2018, 04:15 PM
RE: Need guidance in selecting a Lowboy - by fifties - 03-13-2018, 03:46 PM
