Help identifying a philco model
Ah! Now I see what you are saying.
The tube layout in the Rider's print has an error. Here is a corrected layout:
Help identifying a philco model - by elfiself - 03-12-2018, 03:25 PM
RE: Help identifying a philco model - by elfiself - 03-12-2018, 06:46 PM
RE: Help identifying a philco model - by elfiself - 03-12-2018, 07:16 PM
RE: Help identifying a philco model - by elfiself - 03-12-2018, 07:23 PM
RE: Help identifying a philco model - by elfiself - 03-13-2018, 06:56 PM
RE: Help identifying a philco model - by elfiself - 03-13-2018, 09:17 PM
RE: Help identifying a philco model - by elfiself - 03-14-2018, 08:59 AM
RE: Help identifying a philco model - by elfiself - 03-14-2018, 11:03 AM
RE: Help identifying a philco model - by elfiself - 03-14-2018, 01:29 PM
RE: Help identifying a philco model - by Ron Ramirez - 03-14-2018, 02:35 PM
RE: Help identifying a philco model - by elfiself - 03-14-2018, 04:25 PM
RE: Help identifying a philco model - by elfiself - 03-14-2018, 05:54 PM
There are currently 6426 online users. [Complete List]
» 2 Member(s) | 6424 Guest(s)
