Zenith 8s359
>Appreciate thoughts
It's broke!
Voltages look pretty good. The output stage on this thing is sort of counter intuitive as the control grid of the 6AC5 is positively driven from the cathode of the 6P5. Should get a loud buzz when touching the cap of the 6F5. Have you checked the 6P5 and 6AC5? Do you have a signal tracer?
Zenith 8s359 - by klondike98 - 02-03-2018, 01:56 PM
RE: Zenith 8s359 - by Electrothaumaturgist - 02-03-2018, 05:05 PM
RE: Zenith 8s359 - by murf - 02-03-2018, 05:33 PM
RE: Zenith 8s359 - by morzh - 02-03-2018, 10:20 PM
RE: Zenith 8s359 - by klondike98 - 02-04-2018, 12:22 AM
RE: Zenith 8s359 - by Arran - 02-04-2018, 02:15 AM
RE: Zenith 8s359 - by klondike98 - 02-04-2018, 04:38 PM
RE: Zenith 8s359 - by Electrothaumaturgist - 02-04-2018, 09:02 PM
RE: Zenith 8s359 - by klondike98 - 02-05-2018, 01:51 AM
RE: Zenith 8s359 - by Arran - 02-05-2018, 05:09 AM
RE: Zenith 8s359 - by Phlogiston - 02-05-2018, 11:43 AM
RE: Zenith 8s359 - by klondike98 - 02-12-2018, 01:02 PM
RE: Zenith 8s359 - by OldRestorer - 02-12-2018, 01:38 PM
RE: Zenith 8s359 - by Radioroslyn - 02-12-2018, 02:53 PM
RE: Zenith 8s359 - by klondike98 - 02-12-2018, 08:20 PM
RE: Zenith 8s359 - by Arran - 02-14-2018, 04:22 AM
RE: Zenith 8s359 - by klondike98 - 02-14-2018, 07:15 PM
RE: Zenith 8s359 - by klondike98 - 03-15-2018, 07:48 PM
RE: Zenith 8s359 - by Radioroslyn - 03-15-2018, 08:52 PM
RE: Zenith 8s359 - by klondike98 - 03-15-2018, 09:02 PM
RE: Zenith 8s359 - by Electrothaumaturgist - 03-17-2018, 08:57 PM
RE: Zenith 8s359 - by klondike98 - 03-18-2018, 01:10 PM
RE: Zenith 8s359 - by Radioroslyn - 03-18-2018, 02:05 PM
RE: Zenith 8s359 - by klondike98 - 03-18-2018, 02:13 PM
RE: Zenith 8s359 - by Radioroslyn - 03-18-2018, 05:13 PM
RE: Zenith 8s359 - by klondike98 - 03-18-2018, 07:33 PM
RE: Zenith 8s359 - by Radioroslyn - 03-18-2018, 09:00 PM
RE: Zenith 8s359 - by klondike98 - 03-19-2018, 01:30 AM
RE: Zenith 8s359 - by klondike98 - 03-25-2018, 04:56 PM
RE: Zenith 8s359 - by Radioroslyn - 03-25-2018, 07:14 PM
RE: Zenith 8s359 - by klondike98 - 03-25-2018, 11:26 PM
RE: Zenith 8s359 - by klondike98 - 03-30-2018, 07:47 PM
RE: Zenith 8s359 - by klondike98 - 08-29-2018, 11:44 PM
RE: Zenith 8s359 - by tbone - 08-31-2018, 11:32 AM
RE: Zenith 8s359 - by Eliot Ness - 08-31-2018, 12:15 PM
RE: Zenith 8s359 - by klondike98 - 08-31-2018, 12:29 PM
There are currently 10261 online users. [Complete List]
» 2 Member(s) | 10259 Guest(s)
