RCA 110K2 Unexpected project
Threads: 29
City: Wellborn Florida
Copper welding way above my skill set. You could use number 10 or 12 copper for your rod and something like peterson blue flux and do a copper braze. Might get by with a propane torch or mapp gas. To be honest I would not want to have that much heat inside a radio. Melting point of copper 1984.32F. David
RE: RCA 110K2 Unexpected project - by David - 03-16-2018, 04:23 PM
Users browsing this thread: 26 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9927 online users. [Complete List] » 3 Member(s) | 9924 Guest(s)
