Philco 8974
"8974" doesn't seem like a good number and the pic isn't showing. Is it a radio?
Philco 8974 - by kd4pqf - 05-16-2010, 08:02 PM
Re: Philco 8974 - by exray - 05-16-2010, 11:59 PM
Re: Philco 8974 - by kd4pqf - 05-17-2010, 12:41 AM
Re: Philco 8974 - by Ron Ramirez - 05-17-2010, 06:33 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
