Philco 87 question
UPDATE...
Got brave and soldered the wire back together and rewound the coil...Put it
back together and realign and Neuturalized it and now the lower station come in loud and clear...
Thanks for everone's help on this...
Philco 87 question - by Micro9 - 05-13-2010, 12:01 AM
Re: Philco 87 question - by exray - 05-13-2010, 07:15 AM
Re: Philco 87 question - by 7estatdef - 05-14-2010, 03:25 PM
Re: Philco 87 question - by Micro9 - 05-15-2010, 08:41 PM
Re: Philco 87 question - by Micro9 - 05-17-2010, 12:52 AM
Re: Philco 87 question - by Ron Ramirez - 05-17-2010, 10:23 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
