electromagnet to pm speaker philco
You pretty much insert a resistor equal in ohms to the field coil ohms instead of the field coil.
And connect the voice coil same way it is originally connected.
Tsit.
electromagnet to pm speaker philco - by mg34.42 - 03-18-2018, 09:11 PM
RE: electromagnet to pm speaker philco - by morzh - 03-18-2018, 09:31 PM
RE: electromagnet to pm speaker philco - by morzh - 03-18-2018, 10:01 PM
RE: electromagnet to pm speaker philco - by Arran - 03-20-2018, 04:51 AM
RE: electromagnet to pm speaker philco - by Arran - 03-22-2018, 02:35 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4994 online users. [Complete List]
» 2 Member(s) | 4992 Guest(s)
