Zenith 5S042AT With A 25-Cycle Transformer
Thanks for the reply. You are right about the transformer size. It is huge -- bigger than anything I've ever seen on a table model or tombstone radio.
Re: Zenith 5S042AT With A 25-Cycle Transformer - by 37-670 - 05-18-2010, 09:41 AM
