Threads: 2
City: Madrid, Spain
Now I am waiting for some grommets and spares from USA I am doing the cabinet, I found a paint or some kind of protection that was applied only inside and in the bottom grille that has a silver particles, what it is? Also I printed my own stickers, for the faux finish I tried to paint and shade with tonner, not exactly the old finish but still I like it
Image(s)
RE: Philco 37-610 tombstone restoration - by Jeepeto - 03-20-2018, 08:45 AM
Users browsing this thread: 22 Guest(s)
91H Code 126 Restore
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM
Philco 70 antenna lead
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM
There are currently 4846 online users. [Complete List ]» 2 Member(s) | 4844 Guest(s)
