39-116 Questions?
I'm starting a re-cap on this Philco 39-116. First I tested all the tubes. The #80 rectifier is dead. Filaments are open. Then I noticed that two (2) SK3081 diodes are installed with the cathodes soldered to pin 4 of the 80 and the anodes, one soldered to pin 2 and the other soldered to pin 3 of the 80. Is this an attempt to bypass the 80 rectifier?
Pepperoni
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
39-116 Questions? - by Pepperoni - 03-21-2018, 12:21 PM
RE: 39-116 Questions? - by Radioroslyn - 03-21-2018, 12:28 PM
RE: 39-116 Questions? - by Olskuul - 03-21-2018, 12:41 PM
RE: 39-116 Questions? - by Pepperoni - 03-21-2018, 01:43 PM
RE: 39-116 Questions? - by morzh - 03-21-2018, 03:58 PM
RE: 39-116 Questions? - by Pepperoni - 03-24-2018, 01:04 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6955 online users. [Complete List]
» 2 Member(s) | 6953 Guest(s)
