37-630 Bezel Glass ?
I just purchased a 37-630T to restore. The case is in pretty good shape, as is the rest of the radio. The only thing that seems to be missing is the bezel glass. I measured the bezel opening and the center hole of the outside ring that clamps the glass into the bezel, and the circular piece of glass I will need seems to be 3.30 inches in diameter. I measured the opening in the bezel with my vernier, a hair over 3.30 inches, and also the opening in the clamping ring, it will cover the edges of the glass easily. Does anyone know of a good source of such a piece of glass? A piece of plain window glass cut to a 3.30 inch diameter circle would do perfectly. Thanks for any help in advance, Mike
37-630 Bezel Glass ? - by mikethedruid - 03-21-2018, 10:06 PM
RE: 37-630 Bezel Glass ? - by pull7gs - 03-21-2018, 11:23 PM
RE: 37-630 Bezel Glass ? - by klondike98 - 03-22-2018, 12:40 AM
RE: 37-630 Bezel Glass ? - by Arran - 03-22-2018, 02:26 AM
RE: 37-630 Bezel Glass ? - by mikethedruid - 03-22-2018, 03:53 PM
RE: 37-630 Bezel Glass ? - by Patrick - 04-10-2018, 05:44 AM
RE: 37-630 Bezel Glass ? - by OldRestorer - 04-10-2018, 09:30 AM
RE: 37-630 Bezel Glass ? - by mikethedruid - 06-01-2018, 04:20 PM
RE: 37-630 Bezel Glass ? - by Ron Ramirez - 06-01-2018, 04:48 PM
RE: 37-630 Bezel Glass ? - by mikethedruid - 06-02-2018, 12:57 PM
