Philco 40-95T
Hi Jeff,
Actually your images were added to the Philco 45C as well as the late 37-610T.
We do have some pending Gallery additions - but I don't see anything else from you there.
I have been exercising some editorial discretion over the submissions - trying to add only the most representative examples (e.g. original finish, correct grille cloth) for the photos. It kind of depends though if we already have photos or not.
Pics for the 40-95T would be awesome. Personally, I like that cabinet style too. I've seen them from time to time and will eventually pick one up I'm sure.
-Nathan
Philco 40-95T - by PhilcoPhan1936 - 03-22-2018, 11:24 AM
RE: Philco 40-95T - by Ron Ramirez - 03-22-2018, 12:46 PM
RE: Philco 40-95T - by PhilcoPhan1936 - 03-22-2018, 04:11 PM
RE: Philco 40-95T - by Nathan Slingerland - 03-22-2018, 08:00 PM
RE: Philco 40-95T - by Nathan Slingerland - 03-22-2018, 09:07 PM
RE: Philco 40-95T - by PhilcoPhan1936 - 03-23-2018, 12:00 AM
RE: Philco 40-95T - by Nathan Slingerland - 03-23-2018, 12:23 AM
RE: Philco 40-95T - by PhilcoPhan1936 - 03-23-2018, 12:38 AM
RE: Philco 40-95T - by PhilcoPhan1936 - 03-23-2018, 01:29 AM
RE: Philco 40-95T - by Arran - 03-26-2018, 03:53 AM
There are currently 9754 online users. [Complete List]
» 2 Member(s) | 9752 Guest(s)
