38-7 Tone Control
Crist looks like the control is showing only two connections when you switch it. 1st pos. the .006 cap is in circuit. 2nd pos. no connection and 3rd pos. .008 and .03 cap in circuit. Maybe someone can explain further about why its noisy in pos 3.
38-7 Tone Control - by Crist Rigotti - 03-23-2018, 10:28 AM
RE: 38-7 Tone Control - by KCMike - 03-23-2018, 10:42 AM
RE: 38-7 Tone Control - by Radioroslyn - 03-23-2018, 07:18 PM
RE: 38-7 Tone Control - by Crist Rigotti - 03-26-2018, 03:26 PM
91H Code 126 Restore
