need help 45c restore
I've tested all tubes and replaced the 80 just for grins, no change.Both caps (62) and (63) are
installed neg to the pwr tfmr cntr tap and (58) neg to gnd. Just thought I'd throw that out
just to be sure I've installed them correctly. thanks for the response.
Danny
need help 45c restore - by Danny - 03-23-2018, 01:53 PM
RE: need help 45c restore - by morzh - 03-23-2018, 03:25 PM
RE: need help 45c restore - by Danny - 03-23-2018, 03:47 PM
RE: need help 45c restore - by Radioroslyn - 03-23-2018, 06:20 PM
RE: need help 45c restore - by 45philcodon - 03-23-2018, 07:24 PM
RE: need help 45c restore - by 45philcodon - 03-23-2018, 07:45 PM
RE: need help 45c restore - by PhilcoPhan1936 - 03-23-2018, 08:27 PM
RE: need help 45c restore - by PhilcoPhan1936 - 03-23-2018, 08:30 PM
RE: need help 45c restore - by Danny - 03-24-2018, 11:23 AM
RE: need help 45c restore - by Danny - 03-24-2018, 05:14 PM
RE: need help 45c restore - by Arran - 03-24-2018, 05:36 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2848 online users. [Complete List]
» 2 Member(s) | 2846 Guest(s)
