need help 45c restore
If it's been worked on previously, and they used the Rider's schematic, it's possible the connection was removed, according to the error in the schematic. I have a model 66 that had the same error, and a previous tech removed that connection. I found the wire still curled up under the chassis, and reconnected it, and bingo! Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
need help 45c restore - by Danny - 03-23-2018, 01:53 PM
RE: need help 45c restore - by morzh - 03-23-2018, 03:25 PM
RE: need help 45c restore - by Danny - 03-23-2018, 03:47 PM
RE: need help 45c restore - by Radioroslyn - 03-23-2018, 06:20 PM
RE: need help 45c restore - by 45philcodon - 03-23-2018, 07:24 PM
RE: need help 45c restore - by 45philcodon - 03-23-2018, 07:45 PM
RE: need help 45c restore - by PhilcoPhan1936 - 03-23-2018, 08:27 PM
RE: need help 45c restore - by PhilcoPhan1936 - 03-23-2018, 08:30 PM
RE: need help 45c restore - by Danny - 03-24-2018, 11:23 AM
RE: need help 45c restore - by Danny - 03-24-2018, 05:14 PM
RE: need help 45c restore - by Arran - 03-24-2018, 05:36 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4858 online users. [Complete List]
» 1 Member(s) | 4857 Guest(s)
