42-380 alignment
(03-25-2018, 04:19 PM)spiderdrummer24 Wrote:  Meter is good but that may be my issue. I don't have the adaptor for DC. Only AC voltages. I have another multimeter. I'll try and get a reading on it
On my Heathkit V7, I replaced the DC connector to a BNC which made easier to connect to probes and test leads. Lately I just use a DMM since the input impedance of even the cheap ones are 1 meg or better. However, analog meters are easier to spot the max deflection than a bunch of moving digits.
42-380 alignment - by spiderdrummer24 - 03-25-2018, 01:20 PM
RE: 42-380 alignment - by morzh - 03-25-2018, 02:44 PM
RE: 42-380 alignment - by Radioroslyn - 03-25-2018, 02:54 PM
RE: 42-380 alignment - by spiderdrummer24 - 03-25-2018, 04:19 PM
RE: 42-380 alignment - by whirligig - 03-25-2018, 05:16 PM
RE: 42-380 alignment - by Radioroslyn - 03-25-2018, 07:09 PM
RE: 42-380 alignment - by whirligig - 03-25-2018, 10:29 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4893 online users. [Complete List]
» 2 Member(s) | 4891 Guest(s)
