Radiobar 528-37-650
Thanks Terry.  I'll be sure to check that xfmr.  Same issue with the 55, 60 and 70 series Atwater Kent radios...inter-stage xfmr between the 45 outputs is often bad.
Mike
Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 09:55 AM
RE: Radiobar 528-37-650 - by Radioroslyn - 03-26-2018, 10:44 AM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 11:19 AM
RE: Radiobar 528-37-650 - by Radioroslyn - 03-26-2018, 11:56 AM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 12:48 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 12:52 PM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 03:35 PM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 04:01 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 04:27 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-26-2018, 07:09 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 09:34 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-27-2018, 12:57 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-27-2018, 05:33 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-27-2018, 05:57 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-27-2018, 07:02 PM
There are currently 10181 online users. [Complete List]
» 3 Member(s) | 10178 Guest(s)
